Passenger side A/C only blows warm air
219,000 MILES • V8 • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
Compressor turns freely with hand, A/C on driver side is only cold when driving, warm at idle, passenger side is always warm, is this a common issue on these trucks?
Jul 27, 2019 at 10:04 PM
  • 55,684 POSTS
It sounds like you have two problems. the first is the system is low on charge which we can fix by watching this video.
https://youtu.be/uZrQCGwXfek
The second problem is the passenger side blend door actuator needs to be replaced. here is a guide to walk you through the repairs and diagrams below to show you how on your car:
Apr 23, 2021 at 3:33 AM
NASER NASER
  • 836 POSTS
i was going to check the Freon on it but the compressor never comes on, not unless it's first thing in the morning when you start it, but haven't tried checking it early AM, if its anytime after that the compressor is off until i drive and she starts to cool, also, the condenser fan is off when i park it after i drive it, not sure if the fan needs to be working first for the compressor to come on or that fan comes on later, from what i have seen on different vehicles if the fan isn't working the cooling has issues, but if its low on Freon then why is it that the driver is very cold when i drive only?
NASER NASER
  • 836 POSTS
what should the high pressure and low read in normal range?
  • 55,684 POSTS
It can be low or it could be the compressor is going out along with the passengers blend door actuator. The high side pressure should be about 250 on a hot day.
This guide should help:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
NASER NASER
  • 836 POSTS
Am more familiar with German and Japanese cars, is the condenser fan supposed to come on immediately once the A/C compressor or the A/C is on?
  • 55,684 POSTS
Its comes on when the pressure gets to high in the system is all. If the pressure never reaches the upper limits the fan will not run. This guide will help check the high side pressure
