AC is wandering
110,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
GCARDW
I turn in the air and it will come out of the vents and from the floor. I push the button for defrost and it moves to defrost them I put it back to vents and it blows normally for a few minutes and then starts moving to the floor again. It never moves all the way to the floor. Is this in the blend door or do I need to replace the AC controller?
May 26, 2019 at 8:16 PM
SCGRANTURISMO
  • 4,897 POSTS
In the diagrams down below I have included the factory troubleshooting procedures for your vehicle's Mode Control Door. Please go through this guide and get back to us with what you are able to find out. It calls for the use of a multimeter, so I have included a link below for you to go to if you are unfamiliar with how to use one.
Thanks,
Alex
2CarPros
May 26, 2019 at 10:51 PM
GCARDW
Thanks for the response. I see the link for the multimeter but no diagrams or guide. Thanks
May 27, 2019 at 9:05 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
I am sorry about that. I not sure what happened there. I have included the guide for you in the diagrams down below.
Thanks,
Alex
2CarPros
May 28, 2019 at 10:49 PM
GCARDW
I checked the wiring with the multi-meter. Everything seemed fine and even ordered and replaced the control unit just in case. Still having the same issue. Crawled under the dash and took this video. I couldn't tell exactly what was going wrong. Hoping you guys could help. Thanks
Jun 19, 2019 at 7:37 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
It looks like your actuator is starting to fail. I would replace the actuator.
Thanks,
Alex
2CarPros
Jun 19, 2019 at 11:39 PM
