A/C is cold then gets warm
199,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
ANONYMOUS
A/C will be cold and after a while (15 minutes to 1 hour) it gets warm. If I shut the truck off and back on it's cold again. This will work every time. The A/C is cold normally and when it gets warm the compressor is not on. If I shut the truck off for just a few seconds the compressor will kick on and it's nice and cold again. It could last 5 minutes or an hour. Some days it will work fine, normally when it is a little cooler out.
Mar 5, 2020 at 1:36 PM
Good morning,
Do you have a set of gauges to give me the high and low side readings?
If the low side pressure drops too low, the clutch will disengage and warm air comes out.
Mar 5, 2020 at 9:19 PM
