blowing hot air, on the driver side vents & the passenger side vents blows cold air?
230,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
SUNDAY2813
My Heater is blowing hot air , on the driver side vents & the passenger side vents blows cold air , as soon the vehicle is on ?
The heat blows about 1-5 (3)
The cold blows about (2)
The temperature dial doesn’t work from
1-3 only turns on - 4-5 high
Thank you
Aug 3, 2025 at 4:26 AM
  • 55,694 POSTS
Yep this means the passenger side blend door actuator is not working here is a guide to help you change it out and show you which one is for the right side.
Let us know if you need anything else.
Aug 4, 2025 at 5:25 AM
