AC/heat not blowing
2009 NISSAN SENTRA
167,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MMATTINGLY
Just picked my car up from the mechanic where had the blower motor replaced. Got 3/4 way home and was blowing fine, then just stopped again. Fuses are not blown. Any thoughts?
Aug 20, 2019 at 6:55 AM
  • 110,240 POSTS
Welcome to 2CarPros.
Does it work on any speed? If not, the first thing I would check is the blower motor relay. It is located on the left side under the dash. I attached a picture of the relay and the location.
If you find a relay with the same part number, switch them. If you don't, here is a link that shows how to check a relay:
Here are a few links you may find helpful when testing:
Let me know what you find or if you have other questions. If the fan still works on the high setting only, let me know.
Aug 20, 2019 at 12:45 PM
MMATTINGLY
Not the relay. Not the fuses and not the resistor. Mechanic did not know why was working and just quit. Could it be control panel?
Aug 22, 2019 at 5:53 AM
  • 110,240 POSTS
Welcome back:
It could, but to confirm it I would be checking the things I mentioned first. If they all pass, then he will have to check the control panel. It could even be a bad or weak ground.
Let me know if I can help.
Aug 22, 2019 at 2:34 PM
