AC/heat not blowing
1998 JAGUAR XJ8
211 MILES • V8 • AUTOMATIC
IBSHAKIR
AC/heat not blowing no matter what volume selected. power is showed on display but nothing blowing out at all.
Apr 9, 2018 at 5:20 PM
  • 31,937 POSTS
You will have to get the power at the blower motor tested. normally if the blower resistor fails you do not lose all speeds. check the voltage into the blower motor on all speeds and see what you have. if you have voltage, the motor will probably be faulty.
Apr 11, 2018 at 7:44 AM
