ac/heat fan door closing
150,000 MILES
MW1402
Yes Ive been having a problem with my vehicles ac/heating. Whenever your using either one of them youll be driving and it will quit coming out of the vents. The fan is still running you can still feel the ac/heat which ever one im using at the vents. Sometimes you can drive an hour or so before it does it. Ive stopped before got gas or something and start it up and its working fine for a little while longer. I really don't know where to start. Hate to just start replacing parts. I thought about just rigging the door open but hate to do that as well. Well hope somebody out there has seen this before. Thanks.
May 18, 2013 at 9:26 PM
HMAC300
  • 48,601 POSTS
try pulling your hvac fuse for 60 seconds then reinstall. your actuator may be losing power or not in sync. If it doesn't fix it have it looked at because it could be the control as well isn't working right.
May 19, 2013 at 12:54 AM
