A/C gauge fluctuates when connected to low pressure valve
185,741 MILES
AWONG15
So when I connect the gauge to recharge the A/C it fluctuates from low to the green then back to low after already adding coolant. Why is my A/C still blowing hot air?
Feb 18, 2020 at 5:11 AM
Good afternoon,
Was the system totally out of Freon? If it was, you need to add exactly what the system calls for.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
If you are topping off, you have to be careful not to overfill it.
Can you post a video of what you see with the gauges?
Feb 18, 2020 at 5:48 AM
