My AC is now acting up at a time when it is very nice to have during our summer heat wave. I have checked fuses and all are fine.
When I turn on the car after it was not used for a while, I will get cold air flow for a few minutes, then the air turns warmer. The control unit of the ventilation works normally as if all is fine (LED of the A/C is lit and same if I add the Max A/C, the LED turns on but not cool air).
Same result at every level of the fan speed control.
When the cool air stops flowing, the clutch disengages.
I have trigger the clutch externally with 12 volt jumper and it works. The power simply stops to reach the clutch at some point.
A few days, after first realizing that I have an A/C issue, my car displayed the Service Engine light indicator. Code P0112 was displayed with an OBD2 scanner. Until now, I do not believe that the combined EIT and MAF sensor (with 6 wires) fault code has anything to do with the AC. I could be wrong though.
Any suggestion for the A/C?
Aug 9, 2020 at 1:09 PM
