A/C evaporator temperature sensor
30,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
MIKEYBIGGZ
  • 5 POSTS
What color are the wires that I need to bypass the evaporator temperature sensor until I get the actual sensor replaced?
Sep 11, 2021 at 7:12 AM
SQM
  • 6,383 POSTS
This vehicle being a 2020 and 30,000 miles you should have factory warranty coverage for any issues you are facing.
If you were to bypass any component you could run into issues with the warranty.
Let me know little bit more details.
https://www.youtube.com/c/2carpros/featured
Sep 11, 2021 at 1:02 PM
MIKEYBIGGZ
  • 5 POSTS
The warranty will not cover the repair.
Just want wiring diagram for HVAC in cabin to bypass evaporator temperature sensor.
Thanks for your help.
Sep 12, 2021 at 1:48 AM
MIKEYBIGGZ
  • 5 POSTS
They've replaced everything except the evaporator temperature sensor and will not do that because of labor involved on these models.
Sep 12, 2021 at 1:50 AM
SQM
  • 6,383 POSTS
Got it. Do you have automatic or manual HVAC system on that fusion?
Let me know and I will get you the appropriate wiring.
Sep 12, 2021 at 3:08 AM
MIKEYBIGGZ
  • 5 POSTS
It's the single zone manual HVAC in 2020 Ford Fusion S.
Thank you
Sep 12, 2021 at 4:01 AM
SQM
  • 6,383 POSTS
I have attached the complete wiring schematics for the HVAC system.
Look below.
Sep 12, 2021 at 4:28 AM
MIKEYBIGGZ
  • 5 POSTS
Thanks.
Sep 12, 2021 at 4:39 AM
SQM
  • 6,383 POSTS
You're welcome.
Sep 12, 2021 at 4:46 AM
