AC evap temp sensor malfunction
80,000 MILES
WSIMMONS42
Where is 2007 VW Passat air condition evaporator temp sensor located? Cannot locate. Diagnostic says this needs replacing.
Apr 16, 2013 at 9:53 AM
what is the code??? codes never identify bad parts, just failed systems
the sensor is in the evap housing
Apr 16, 2013 at 9:59 AM
WSIMMONS42
Need to how to remove AC evap temp sensor on 2007 VW Passat.
Apr 16, 2013 at 10:03 AM
FREEMBA
  • 1,152 POSTS
locate the blower motor below the dashboard on the passenger side of the interior of the car. About 10 iinches to the left of the blower motor is the temp sensor (it is the second electrical connection you will come to--it's held in be a couple of small screws). On the attached diagram it is item #28.
Apr 16, 2013 at 10:26 AM
FREEMBA
  • 1,152 POSTS
Sorry about the picture no coming through. This is yet another attempt. Hopefully the third time is the charm.
Apr 16, 2013 at 10:35 AM
