AC erratic
70,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
KTHSAN
With the AC on fan speed 5 it runs fine then stops blowing. I then drop the fan to 4 and it will work fine. After a short time it starts blowing hot air, even after recharge. Turn everything off including the vehicle wait a few minutes and start the vehicle up and the AC will run fine for a little while and then the problems starts all over again. Some days it runs without an issue.
Jul 3, 2018 at 3:24 AM
Good evening.
From your description, it sounds like you need a blower resistor for the fan. That will keep the blower operating.
As far as the AC, do you have gauges to check the pressures?
Jul 3, 2018 at 9:51 AM
