AC dryer replacement
199,000 MILES • 3.4L • 4 CYL • 2WD • AUTOMATIC
KEVIN KIMBRELL
How do you replace the AC dryer?
Jun 5, 2019 at 9:50 AM
Hi Kevin,
Here is the procedure for replace the dryer. Keep in mind you will need to evacuate the system before and after and pull it into a vacuum after you are finished. You need to make sure you do this after because you have to get the moisture out of the system or it will damage the compressor.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Let me know if you have more questions and I will be happy to assist. thanks
Jun 5, 2019 at 10:15 AM
