A/C drain hose
122,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
IMAGING
  • 151 POSTS
In the pic below, the hose with the drop of water (leak), is that the A/C drain hose?
Jul 5, 2021 at 6:23 AM
That is correct. This is the evaporator drain so when the cold air goes over the evaporator it causes it to sweat and this is the drain in the HVAC housing that allows the water out.
Take a look at the diagrams below. It is number 2 in the second one. However, your vehicle has a rubber hose attached to the end of it just to extend the water down past the other components so it leaks directly onto the ground.
Let us know if you have other questions. Thanks
Jul 5, 2021 at 10:08 AM
