Trying to change A/C relay fuse under hood
200,000 MILES • 2.5L • 4 CYL
PEEZY13
Trying to change A/C relay fuse under hood on passenger side, can get cover off, but can't pull out box to get to fuses and relay.
Sep 17, 2020 at 10:06 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Sometimes it takes a lot of wiggling and pulling to get the relay out. I've attached a picture below in case you need the proper location.Once removed here is a tutorial to view on how to test a relay:
Keep us updated as to your progress.Hope this helps and thanks for using 2CarPros.
May 25, 2021 at 4:28 AM
