AC is not working
2,700,000 MILES • 1.6L • 2WD • MANUAL
TIGANY ALI AHMED NOOH
We I press the button no response at all, even does not light up.
Mar 15, 2018 at 6:49 PM
Good morning.
The first thing I would do is have the freon tested for correct pressure. Without proper pressure the AC will not come on line.
You can get a set of gauges at a parts store. they will rent them to you. once you get them, let me know what pressures you see.
Also, check all your fuses. use a test light and check for power on both sides with the key on.
Mar 15, 2018 at 8:06 PM
