AC does not start till...
ALL OTHER MAKES ALL OTHER MODELS
PATMAC573
I will turn AC on (any & all settings) and the compressor will not come on until whenever it gets ready to.When it does start 5- 20 mins. later it works fine get to 43 degrees as long as it stays running or until I cut te ac off and then it starts from square one. It has 100% brand new fresh freon it too. Please help!
Apr 13, 2013 at 10:40 AM
  • 31,937 POSTS
make and model and engine i need more info.
Apr 13, 2013 at 4:58 PM
PATMAC573
To : mhpautos my bad it is in here somewhere,I put it in at the start and thought it showed it. It is a 2002 Lincoln LS with the 3.9V8
Apr 13, 2013 at 6:00 PM
  • 31,937 POSTS
Did you put the correct weight of refregrant in? you may have over filled the system.
Apr 13, 2013 at 8:55 PM
PATMAC573
yes all brand new -26 oz
Apr 13, 2013 at 10:01 PM
  • 31,937 POSTS
Sounds as if it is an an electrical fault, have you power at the A/C clutch when you first turn the system on?
Apr 14, 2013 at 7:22 AM
