A/C condenser fan not turning on
150,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
OROBATEAU
A/C blows cold and heater works fine. The condenser fan in the front is not turning on which causes the engine to get hot only when the A/C is on.
Jun 8, 2020 at 2:27 PM
  • 55,834 POSTS
9 time out of 10 it will be the motor or the relay. here is a guide to help check the relay. We should check the fuses as well. I have included the wiring diagrams for the air conditioner so you can see how the system works. Here are the fuse locations as well:
and
See if the motor is getting power by using a test light on the blue/black wire when the system is on. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Jun 9, 2020 at 5:17 AM
