ac condenser fan doesn't come on
180,000 MILES • 2.5L • V6 • FWD • AUTOMATIC
MARY R
My ac condenser fan does not work. I have 12 volts at the fan connector. I tried running battery voltage to the fan. But it didn't turn on.
Am I safe to assume I need a fan motor? Or are these things controlled on the ground side? I have the schematic and it looks like this is the case however it is way too complex for me to follow. Thank you for your help.
May 19, 2014 at 2:52 AM
WRENCHTECH
  • 20,760 POSTS
Yes, it is a very complicated circuit. The grounds side goes through 2 different relays and a control modules and testing it will be real difficult.
May 19, 2014 at 4:58 AM
