AC Condenser
212,000 MILES
JESSNZACH10
  • 6 POSTS
my buddy cut the lines on my ac condenser and i believe my power steering and brake fluid cooler also when removing my radiator. do i need this for the car to be operational or will it just affect my ac?
May 27, 2013 at 9:13 AM
SINBAD271
  • 169 POSTS
No power steering equals harp to turn steering wheel. No brake fluid equal no stopping the vehicle. I seriously doubt your friend cut a brake fluid cooler . Are you sure it wasn't the trans cooler?
May 27, 2013 at 9:26 AM
JESSNZACH10
  • 6 POSTS
no its brake fluid and that i can hook back up but its the ac condenser i cant hook back up unless i replace the whole aluminum lines im guessing cuz they are clamped on both sides into aluminum lines
May 27, 2013 at 9:30 AM
SINBAD271
  • 169 POSTS
After you replace the lines you must evac and recharge the a/c system. You can still drive the vehicle with out a/c. Though it will be hard to steer without power steering.
May 27, 2013 at 10:01 AM
