A/C compressor pulley is close to falling off?
157,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
NATE08141993
Ac seized awhile back but was still able to drive. Yesterday a squealing noise started when I used my defrost. Crawled underneath and it looks like the A/C pulley is about to fall off. looking for a cost-efficient solution.
May 3, 2025 at 10:46 AM
MECHTRIX
  • 591 POSTS
Not much you can do with that at this point it sounds like it's time to get a new A/C pump and they usually come with a new pulley that about the only solution i can think of if you have a bad pump and a bad pully. good luck .
May 3, 2025 at 2:15 PM
  • 55,732 POSTS
Yep, I agree with MECHTRIX, the A/C compressor will need to be replaced.
Here is a guide and video to help you through the steps:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
And this video will show you how to vacuum down and recharge the system:
https://www.youtube.com/watch?v=4EqdrBVb0sY
Check out the images (below). Let us know how it goes.
May 5, 2025 at 2:47 AM
