A/C compressor or blend door actuator problem
2013 CHEVROLET CAMARO
84,000 MILES • V8 • 2WD • AUTOMATIC
TRIPP21
My A/C is blowing hot air, but towards end of winter season I noticed the heat wasn't getting really hot as usual and I was having problems with the defrost as well.
How do I know if this is an A/C compressor or blend door actuator problem?
May 12, 2021 at 8:39 PM
You are correct that this could be either of these issues. So the best thing to do is check the compressor first.
We need to turn the A/C on and see if the compressor is engaging under the hood.
We need to check the pressures next. Hook up a gauge set and test it with the A/C off engine running and then turn the A/C on and see what the pressures do.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Once we know the pressures and that the compressor is engaging we will have a better idea if this is a compressor issue.
Here is a guide on blend door replacement if we have to go that way:
https://youtu.be/tY6M92fA2ug
Lastly below is a chart that will help with possible issues with the pressures. Let me know what you find with this and we can go from there. Thanks
May 14, 2021 at 12:10 PM
