A/C compressor and engine fans are not spinning?
138,000 MILES • 6.2L • V8 • 4WD • AUTOMATIC
COLEWILEY21
Fans are not spinning, compressor clutch not engaging, fuses to my knowledge seem fine. Heat works A/C blows hot air.
Apr 8, 2023 at 9:28 AM
  • 110,251 POSTS
If the fuses are good, make sure the connection to the compressor clutch is in good condition and tight.
Keep in mind, there are a few things that can cause this to happen. If the low-pressure switch is faulty, it may not allow the compressor to engage.
Next, if the Freon is low, that will cause the pressure to drop and actuate the low-pressure switch to avoid it from engaging.
Do me a favor. Take a look through this link and let me know if anything is helpful. It goes through things to check and how to repair them when the system doesn't engage.
Let me know if that helps.
Take care and Happy Easter,
Apr 8, 2023 at 3:08 PM
