Ac compressor clutch will not pull in
220,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DKEEN
  • 18 POSTS
Checked Freon and pressures good, if I pull relay and jump terminals 30 to 87 compressor will run and cool down, the switch on panel is on for AC and the fan switch is on. The system seems good but electrically not so sure of. It has three wire switch on high side line cannot find low side.
Jun 12, 2018 at 11:55 PM
Good afternoon.
Did you check for two powers at the relay? 30 should have voltage and 86 should have voltage.
There is only one pressure switch. you need to verify 5 volt reference signal from the switch.
Jun 13, 2018 at 9:07 AM
DKEEN
  • 18 POSTS
I checked and had both voltages at relay and had 5 volts at pressure switch.
Jun 14, 2018 at 9:11 AM
DKEEN
  • 18 POSTS
Have changed relay.
Jun 14, 2018 at 9:13 AM
Okay, the PCM is what grounds the control side of the relay when it gets the correct signal from the pressure switch.
You have a 5 volt reference, a ground and a signal wire that go from the pressure switch back to the PCM.
What are the pressures in the system?
Jun 14, 2018 at 9:30 AM
DKEEN
  • 18 POSTS
35 and 135.
Jun 14, 2018 at 10:13 AM
DKEEN
  • 18 POSTS
With jumper in, sorry.
Jun 14, 2018 at 10:14 AM
DKEEN
  • 18 POSTS
85 low side and 35 high side jumper out not running.
Jun 14, 2018 at 10:20 AM
DKEEN
  • 18 POSTS
High side went to 45.
Jun 14, 2018 at 10:21 AM
DKEEN
  • 18 POSTS
High side slowly climbing at 55.
Jun 14, 2018 at 10:25 AM
Okay, the 35 and 135 are not bad.
You will need to check that transducer or switch.
Back probe the switch. You should have 5 volts on the feed, one is ground and the other is the signal. Can you tell me the voltage on the signal wire?
Jun 14, 2018 at 10:29 AM
DKEEN
  • 18 POSTS
3.2 volts.
Jun 14, 2018 at 10:41 AM
DKEEN
  • 18 POSTS
Correction 4.6 did not have a good connection.
Jun 14, 2018 at 10:42 AM
What color wire?
If that is the signal wire, that should be good enough to ground the relay and turn on the compressor.
Jun 14, 2018 at 10:43 AM
DKEEN
  • 18 POSTS
Red and black - red wire is the signal.
Jun 14, 2018 at 10:45 AM
DKEEN
  • 18 POSTS
Sorry, grey wire is 5 volts.
Jun 14, 2018 at 10:46 AM
Okay.
You need to check the wire at the PCM next. Check the diagram and go to the connector and pin number. Back probe the wire for the relay control. See if there is any voltage there with it hooked up to the PCM.
Jun 14, 2018 at 10:58 AM
DKEEN
  • 18 POSTS
I checked conductivity on both wires red-signal and the black ground from the pressure switch connector back to the PCM connector and they checked good. Could not get on connector to check the voltage with it plugged in.
Jun 14, 2018 at 11:51 AM
Okay, you need to check the wire from the relay to the PCM. It is the dark green/white wire from the relay to the PCM. You need to see if there is voltage at that wire at the connector.
With the plug removed you should have voltage and when you plug it in, it should not have voltage.
Jun 14, 2018 at 7:49 PM
DKEEN
  • 18 POSTS
I pulled the relay and probed the coil side of the relay in the base of the connector and I had power with relay out twelve volts, I reinstalled the relay and had some jumpers in with relay prongs and when I plugged the relay back in I lost power to the coil side of the relay. The voltage I had was twelve volts. I am assuming there is a triac output in the PCM is the reason for this?
Jun 17, 2018 at 9:17 PM
The control side power is controlled by a fuse from the fuse block. The ground for the control side is controlled by the PCM and that is based on the signal from the pressure switch.
If the dark green/white wire has voltage, then it is not being commanded to ground. It should 0 volts if it is grounded.
Do you have a scan tool to monitor the operation of the AC commands?
Jun 17, 2018 at 9:24 PM
DKEEN
  • 18 POSTS
I do not have a scan tool.
Jun 17, 2018 at 9:43 PM
Okay, then if you cannot borrow one or rent one, then we will have to do this check manually as I suggested.
Jun 17, 2018 at 10:03 PM
DKEEN
  • 18 POSTS
I am going to borrow a scan tool tomorrow and check it and I will let you know.
Jun 18, 2018 at 1:15 AM
Sounds good. Keep me updated.
Jun 18, 2018 at 4:59 AM
DKEEN
  • 18 POSTS
Carried car to shop and put the scan tool on it and the following is what we found:
1. The high side pressure sensor was reading or showing (444.92 psi).
2. The high side pressure sensor volts was (4.92 volts).
3. A/C relay command was (off).
4. A/C request signal was (no), but we had the switch on and blower on.
5. FC relay 1 command was (on).
We drain system and pulled the orifice and was very dirty and had look like alum metal shavings on it. I feel like the condenser maybe stopped up? So at this point I am not real sure if I need to replace it all and do not mind if it will fix it. We tried to force the compressor on with scan tool and it would not come on. Said it was on by the screen, so that is the problem is something else bad also like ECM also. Strange but the small line from the evaporator was ice cold but the large line was cool and got cool air out vents for a minute and then warmed up when we where checking everything with the jumper in contacts on relay base. Also, wondering about the high pressure seems real high. And I do need one of these scan tools they are nice?
Jun 20, 2018 at 12:59 AM
Okay, yes 400 is way high. The aluminum is the key. I would suggest a compressor, condenser, orifice and a dryer. Flush the system of all debris.
No, to the ECM. It may have sent a command but the compressor did not kick on. That may be a compressor issue.
Jun 20, 2018 at 2:27 AM
DKEEN
  • 18 POSTS
Okay, I will let you know what happens when I get all this done. Thanks
Jun 20, 2018 at 2:42 AM
Sounds good. keep me updated.
Feel free to return with additional questions.
Jun 20, 2018 at 3:55 AM
