AC Compressor Bypass
93,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
AARON PORTER
So, according to the mechanic, I have a bad air conditioner compressor on my vehicle and he is wanting to replace it. I am trying to save a few bucks and simply bypass it, but I cannot seem to find a straight answer on if that is possible. According to my research, there are three drive belts instead of one long serpentine belt, and one of those belts goes to the air conditioner compressor. Could I bypass the air conditioner compressor by simply removing that belt, or does the system need all three belts spinning to work correctly? Also, is there any other way to bypass the air conditioner compressor if removing the belt is not the answer?
Nov 16, 2016 at 1:04 AM
HMAC300
  • 48,601 POSTS
we only show the one belt going to air conditioner compressor just disconnect it. as long as it does not operate anything else you should be okay .
Nov 16, 2016 at 1:38 AM
AARON PORTER
Awesome. That is what I was hoping. Thanks for the help!
Nov 16, 2016 at 1:40 AM
  • 55,770 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Nov 18, 2016 at 1:12 AM
