ac compressor and fan does not come on
97,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
MICFALLS
ac compressor and fans do not come on when you turn on the ac. Freon is at 80psi on the low side.
Mar 14, 2014 at 8:11 AM
TY ANDERSON
  • 719 POSTS
There is a pressure switch on one of the a/c hoses that cans cause the cooling fans/compressor no to turn on. A bad a/c relay would cause this. The main a/c control panel can also cause this.
If your good with a voltmeter we can go further because this is an electrical issue.
Mar 15, 2014 at 3:12 AM
