Replaced bad compressor. AC fuse is good. Could not put any r-134 into low pressure line. Made jumper connector and ran power to battery. Engine on, connect jumper and clutch engages and takes can of r-134. Reconnect regular connector and clutch does not engage. One small can did not make any temperature difference while jumped over. Do not want to overcharge system or blow a line. All thoughts welcomed. No multi-meter. Have test light.
Jul 20, 2017 at 8:16 AM
