AC compressor
119,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
ALEX19899
  • 171 POSTS
Recently had a shop replace the AC compressor. Once I was inside of the car the AC was cold but once I was driving it home it went hot. The AC compressor does not engage. What would be the causes for this? Would it be too low on Freon?
Jun 21, 2018 at 11:23 AM
Good morning.
Yes, it sounds like you have a leak and all the freon left the system.
I would return to the shop and have them recheck there work to be sure there is no leaks.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Jun 21, 2018 at 10:30 PM
ALEX19899
  • 171 POSTS
Took it in today and mechanic told me the AC compressor is not getting voltage and the AC condenser is leaking.
Jun 22, 2018 at 8:17 AM
Makes sense. If the condenser is leaking and the Creon level pressure gets below 20 on the low side, it will cut off voltage to the compressor.
Your mechanic should know this. If he does not, maybe it would be better to take it to someone who knows AC systems.
Jun 22, 2018 at 8:31 AM
ALEX19899
  • 171 POSTS
What is the process after they replace the condenser?
Jun 22, 2018 at 10:50 AM
They should evacuate the system for forty five minutes. Watch for any leaks, charge the system and recheck for leaks.
Jun 22, 2018 at 10:52 AM
ALEX19899
  • 171 POSTS
Are AC lines suppose to be cold?
Jun 22, 2018 at 11:38 AM
The low side will be cold. The high side will be hot.
Jun 22, 2018 at 11:41 AM
ALEX19899
  • 171 POSTS
Also, I went over a speed bump I heard a loud clunk from the left tire. Would that be my shocks?
Jun 22, 2018 at 5:44 PM
Very possible. Could be the strut mounts.
Jun 22, 2018 at 9:21 PM
ALEX19899
  • 171 POSTS
Is it normal for the power steering pump to vibrate?
Jun 23, 2018 at 8:02 AM
No, please explain what you mean by vibrate.
Jun 23, 2018 at 10:28 PM
ALEX19899
  • 171 POSTS
When I place my hand on the power steering reservoir there is a lot of vibration.
Jun 24, 2018 at 12:21 AM
Make sure it is mounted secure.
Can you post a picture?
Jun 24, 2018 at 12:37 AM
