Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Jul 22, 2023 at 5:43 AM
LIONELL8732
MEMBER
So, after installing the A/C compressor, it clicks on and blows cold and strong. So, I took it on a highway drive and click the knob over to setting 2 after about five minutes of running the air went from blowing strong to blowing low and now, I'm confused and don't know what to do next. Any idea of what to look into next?
Jul 31, 2023 at 2:01 PM
✓Experienced Mechanic
It sounds like the system needs a small amount of refrigerant added because it sounds like the evaporator is icing up and stopping the air flow. Can I ask what the high and low side readings are, please give me the ambient air temperature as well.
Aug 1, 2023 at 3:09 AM
LIONELL8732
MEMBER
Okay.
Aug 4, 2023 at 4:14 AM
LIONELL8732
MEMBER
So, my wife called me and said that the A/C is now blowing hot air so I'm like okay. We just replace the A/C compressor like what now so once she arrived home i hook up my scan tool and i be darn its the nightmare trouble code P0537.
Aug 5, 2023 at 7:14 AM
The P0537 trouble code in a 2007 Mercury Milan refers to an issue with the Ambient Air Temperature Sensor Circuit. Here is the location of the sensor so you can change it out. Check out the images (below). Please let us know what happens.
Aug 7, 2023 at 2:56 AM
LIONELL8732
MEMBER
I am having trouble locating the ambient temperature sensor.
Image (Click to enlarge)
Aug 13, 2023 at 2:44 AM
LIONELL8732
MEMBER
Help.
Video (Click to enlarge)
Aug 13, 2023 at 6:16 AM
Thanks for the video, sorry for the trouble, they can hide the sensor sometimes. It shows the sensor near where you have the wiring harness going to the SRS impact sensor. Check out the images (below). Please let us know how it goes.
