AC compressor
120,123 MILES • 3.5L • 6 CYL • 2WD
DADDYA
  • 29 POSTS
I installed a new expansion valve, receiver/dryer and compressor. The new compressor has the correct amount of page 46 for Chrysler 300. vacuumed the system do you add any more oil ?
May 29, 2017 at 3:42 AM
CARADIODOC
  • 34,407 POSTS
Typically we pour the oil out of the old compressor and measure it, then put that amount, plus about a teaspoon amount for each hose or other component into the compressor. From there, it will circulate through the system. That oil is put in the compressor before it's installed. I would not add any oil for the expansion valve.
May 30, 2017 at 5:38 AM
DADDYA
  • 29 POSTS
Thanks for the tip .
May 31, 2017 at 9:21 PM
  • 55,579 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Cheers, Ken
Jun 3, 2017 at 5:40 AM
