AC clutch not engaging
73,000 MILES • 6 CYL • 2WD • AUTOMATIC
RWJ1
AC clutch will not engage. Checked the fuses but cannot find the AC relay. Does it have one and if so where?
Thanks
Jul 25, 2018 at 3:39 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
The A/C relay is built into the power distribution box and is not serviceable (information attached). However, the A/C system has a cutout switch that will shut compressor off if low refrigerant level is detected. Has the system been checked/serviced/refrigerant added lately? Hope this helps and ask any questions if needed. Thanks for using 2CarPros.
Danny-
Jul 25, 2018 at 4:36 AM
RWJ1
Danny:
It does have low refrigerant and It will not take it without the compressor running. Is there a way to make the compressor run? Also, where is the cut off located and can it be tested with an ohm meter?
Thanks
Jul 26, 2018 at 1:12 AM
DANNY L
  • 5,648 POSTS
Hello again.
I will check and get back to you on that. By the way, if you use those do-it-yourself cans you buy at your local auto parts if you charge it eventually enough will enter and the compressor will begin to cycle. That is if the system has no problems. Just a thought.
Danny-
Jul 26, 2018 at 5:33 AM
