Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Sierra
Climate Control
Air Conditioner
Compressor
Bypass
A/C compressor started smoking, can I bypass it?
1996 GMC SIERRA
180,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
JEFFB333
MEMBER
I will not be able to replace it until payday in a week. Is there anyway to bypass it until then?
Sep 21, 2020 at 6:53 AM
Experienced Mechanic
Good afternoon,
Yes, A/C was an option and they offered a belt for no A/C.
You will need to go to a parts store and get the belt for no A/C.
I attached the diagram routing for you without the compressor.
Image (Click to enlarge)
Sep 21, 2020 at 7:01 AM
JEFFB333
MEMBER
Okay. I don't have that pulley that would bypass it.
Sep 21, 2020 at 7:04 AM
You do not need a pulley in its place.
The belt just does not go around the compressor. You leave the compressor in place.
Sep 21, 2020 at 7:07 AM
I just attached the belt number for you. Go to a parts store and tell them that is the belt number you need.
Sep 21, 2020 at 7:10 AM
JEFFB333
MEMBER
Okay. I tried that belt and it's loose because it doesn't have the bypass pulley installed. Would pulling the A/C relay work?
Sep 21, 2020 at 7:55 AM
Does it smoke with the A/C commanded off?
Sep 21, 2020 at 7:58 AM
JEFFB333
MEMBER
I pulled it and there was no smoke or burning smell.
Sep 21, 2020 at 8:16 AM
Good, then the clutch is the issue.
Leave it out until you get it repaired.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Sep 21, 2020 at 8:36 AM
JEFFB333
MEMBER
Okay, thank you so much.
Sep 21, 2020 at 8:52 AM
You are welcome.
Always glad to help.
Sep 21, 2020 at 8:55 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
