A/C compressor and condenser replacement
127,500 MILES • 5.3L • V8 • 2WD • AUTOMATIC
KBOGUE
I am replacing the A/C compressor and the condenser. Do I need to evacuate the system or just put in the R134 and oil if needed?
May 31, 2018 at 12:42 PM
STEVE W.
  • 15,415 POSTS
If you are replacing those you should also flush the system, put a vacuum on it to be sure it holds then add in a full charge of oil. If you are using a new compressor be sure to drain it before you install it. Then just add enough oil to what you drained to make the full charge amount.
If you do not pull a vacuum on the system you will end up with air and moisture in there with the oil and R134A. The air will cause problems and the moisture will cause acid formation. Both are bad things.
If you have only front AC you need 8 oz of PAG oil. If you have front and rear AC you need 11oz.
For the R134A - Front AC only - 1.8 pounds.
Front and rear AC - 3.0 pounds.
May 31, 2018 at 12:54 PM
KBOGUE
How can I DIY pulling the vacuum from home?
May 31, 2018 at 12:58 PM
KBOGUE
The compressor is making a noise, so I took off the belt so it will not lock up. Is it possible it has a leak and just needs to be fixed and refilled?
May 31, 2018 at 12:59 PM
KBOGUE
You said to flush it. How do you do that?
May 31, 2018 at 1:02 PM
STEVE W.
  • 15,415 POSTS
Take a look at this guide. It should answer some of your questions.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
However, if your compressor is making noise you will need to flush the system as well. For that you buy AC flush, it is a pressurized bottle you attach to the system to flush out debris. In your case you will remove the compressor, the condenser and the lines. Then flush the evaporator core in the reverse of system operation. Then each line. You may want to replace the accumulator/dryer as well. Then flush the disconnected lines. Replace all the o-rings and reassemble the system. Then vacuum it and charge it.
There are no DIY methods for pulling the vacuum, that takes a pump that can pull a true vacuum. You can sometimes get the pump and gauges as loaner tools but they may ask you for a 609 card these days. That is the certification for working on mobile AC systems. A
Another option would be to do the flush and parts replacement, then take it to a shop for the vac/recharge. Just be sure to tell them what you did repair wise.
Jun 1, 2018 at 4:17 PM
