Ac compressor
1993 CHEVROLET LUMINA
147 MILES • 4 CYL • AUTOMATIC
LRICHARDSON19
Yesterday my ac compressor seized and caught on fire. It broke the serpentine belt. It no longer turns period. What I want to know is is it ok to get a belt that bypasses the compressor? I just need to do it until I can afford another compressor
Jun 22, 2019 at 8:48 AM
Hi LRichardson,
Yes. You can just look one up that says with out air conditioning and then follow the same routing except the AC compressor.
Worst case scenario you can look up a dummy pulley that you can put in place of the compressor. This means you just remove the compressor and then install this pulley and you can use the same stock belt with AC.
Let me know if you have any other questions. Thanks
Jun 23, 2019 at 4:46 AM
