ac compressor does not engage
148,787 MILES • 4.3L • V6 • RWD • AUTOMATIC
TATOSHOP
just eliminate rear A/C. replace ac compressor and dryer, vacuum the system add oil and refrigerant and the clutch does not want to engage. i check relays and fuses they are okay. can anybody help please? this is a handicap vehicle that my wife and i use to drive my daughter around and here in Florida the heat is no joke. Thanks.
Aug 29, 2017 at 11:45 AM
WRENCHTECH
  • 20,760 POSTS
There are three fuses you need to confirm as good using a test light. After that test for power at both sides of both the low pressure switch and high pressure switch with the AC on.
Aug 30, 2017 at 3:35 AM
