AC clutch not cycling
103,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
SUGARHILL7380
so A/C was not as cold as should be. used AC pro can. A/C was on bit low side. filled up system a bit and everything seemed to work fine. drove truck the next day and only blowing warm air. A/C clutch engaging for a second or two then shutting off. put A/C pro gauge back on to check pressure. when clutch engages the pressure drops then shoots back up into yellow zone when clutch disengages. If the system is overcharged, how do i properly depressurize it?
Aug 3, 2017 at 9:20 AM
  • 55,748 POSTS
You might need to put both gauges on it to see whats going on. Here are a couple of guides that can help you get the problem fixed.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
and
Cheers, Ken
Aug 5, 2017 at 12:16 PM
