AC Causes Limp Mode 2000 F150
250,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CRAIG M
  • 21 POSTS
This truck has had this problem for over a decade. The AC works great, but after it runs for about an hour, the engine temp shows normal then jumps to hot and the engine goes into limp mode. The code given is engine temp sensor. It has been replaced several times, but the condition continues. When the ac is not used, the truck never has the problem.
Aug 10, 2025 at 3:20 AM
  • 55,764 POSTS
To me it sounds like the fan clutch is bad, can you hear it kick in when the engine is running hot and overheating? Can I ask which code is triggered? Here is a guide to help see if the fan clutch is bad or not.
https://www.2carpros.com/articles/fan-clutch-symptoms
This video will show you how to swap the fan clutch out.
https://www.youtube.com/watch?v=PoVQpbkCvtc
Please upload pictures or videos in your response so I can see what is going on.
Aug 11, 2025 at 2:16 AM
CRAIG M
  • 21 POSTS
The truck is not overheating. The fan is working correctly. The temp gauge goes from normal to pegged and into limp mode. I believe it is connected to the ac wiring, possibly shorting something out.
Aug 11, 2025 at 3:04 AM
  • 55,764 POSTS
Okay, so the PCM controls the output to the temp gauge. Lets remove the WOT relay to see if it makes a difference. Here is the location. Please let us know what happens.
Aug 11, 2025 at 5:44 AM
CRAIG M
  • 21 POSTS
I will try that. Does it make a difference if it’s never happened during wot?
Aug 11, 2025 at 7:28 AM
  • 55,764 POSTS
No, if this relay is shorted it will back feed into the PCM causing the issue you are having.
Aug 12, 2025 at 1:26 AM
CRAIG M
  • 21 POSTS
I ran the ac for awhile then pulled out the wot relay. The compressor quit working and when I pulled the relay out it was very hot.
Aug 12, 2025 at 9:41 AM
  • 55,764 POSTS
Okay, you may have an AC compressor coil that is starting to short out, I would use a voltmeter to test the coil, the A/C compressor clutch coil should typically measure between about 3.5 and 4.5 ohms when tested at room temperature. Here is a guide to help you.
Please go over this guide and get back to us.
Aug 13, 2025 at 3:11 AM
CRAIG M
  • 21 POSTS
Coil connection shows 3.8 ohms.
Aug 14, 2025 at 2:52 AM
  • 55,764 POSTS
Okay, so that seems okay but this test is not 100% accurate. Can you put 12 volts to the coil to see if it closes? Lets try this, leave the AC compressor unplugged but then turn the system on for an hour to see if the problem goes away. My thought is when the coil gets hot is shorts out causing the issue.
Aug 15, 2025 at 3:58 AM
CRAIG M
  • 21 POSTS
I ran it with the compressor disconnected and the air turned on for4 hours. It did not shut down and go into limp mode. You’re probably correct about the ac coil wiring. Should I replace just the coil or whole clutch assembly? Or could it possibly be the wire or connector to the coil?
Aug 17, 2025 at 7:24 AM
  • 55,764 POSTS
The problem is the clutch coil, I would see if you can find one which you can replace separately. If not you will need to replace the compressor, this video will show you how to vacuum down and recharge the system.
https://www.youtube.com/watch?v=4EqdrBVb0sY
Let us know how it goes
Aug 18, 2025 at 3:27 AM
CRAIG M
  • 21 POSTS
I ordered a motorcraft coil. I will let you know how it works out.
Aug 18, 2025 at 3:57 AM
  • 55,764 POSTS
Sounds good, it would be great if we could fix it after all these years :)
Aug 18, 2025 at 3:58 AM
CRAIG M
  • 21 POSTS
I replaced the coil on the ac, but it wasn’t driven much and I thought it was fixed. My granddaughter got her dl and started driving it more often. Today it started doing the same thing it was doing originally. What next???
Jun 11, 2026 at 4:36 PM
  • 55,764 POSTS
Yep, this points towards a bad PCM. I would send it in for testing, we use this company they have been pretty good.
https://www.flashmastersecm.com/
Please let me know what happens.
Jun 12, 2026 at 10:02 AM
CRAIG M
  • 21 POSTS
I replaced the pcm and granddaughter has been driving it for a couple of months. It finally did the same thing again. Truck went into limp mode and check engine light came on, water gauge pegged instantly and oil light came on.
Jul 31, 2026 at 2:54 PM
CRAIG M
  • 21 POSTS
Dtc codes
Jul 31, 2026 at 4:07 PM
  • 55,764 POSTS
I had a thought that the pig tail connector at the cylinder head temperature sensor is bad. I would replace it. Here is a link to it.
https://amzn.to/4z74Osi
7 bucks. Let me know
Jul 31, 2026 at 7:09 PM
CRAIG M
  • 21 POSTS
Did not replace pigtail, but have not had problems lately.
Nov 20, 2026 at 9:39 AM
  • 55,764 POSTS
Yep, sometimes the connection will fix itself, if it comes back I would replace the pigtail.
Nov 20, 2026 at 5:06 PM
