AC bypass serpentine belt?
186,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
GEOFFREY KARR POLLOCK
I need to know which serpentine belt to buy in order to bypass AC compressor on my vehicle?
Oct 15, 2016 at 12:55 AM
AL514
  • 5,700 POSTS
Just ask at the auto parts store for the belt for the same vehicle but without air conditioning. I have had to do this same thing for a friend who had their air conditioner compressor go bad. Here is the diagrams for the belt so you can get an idea of the belt size you might need to try more than one.
https://www.2carpros.com/diagrams/hyundai/santa-fe/2003
Oct 15, 2016 at 5:23 AM
KJKOBER
Hey,
I saw your reply with the belt size to bypass the a/c pulley for a Santa Fe, but I've got the 3.5 V6.
Do you know which belt I could use? The clutch/bearings are shot on the compressor, and I don't need the a/c.
Thanks!
Jul 29, 2019 at 6:37 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
You can't just bypass the A/C on that car. There has to be something in the position of the compressor to route the belt around. It does not have a clear path between the remaining pulleys.
KJKOBER
so...a new compressor or new pulley/bearing? I can't find a bypass pulley that is compatible. Any other thoughts? Thanks
WRENCHTECH
  • 20,760 POSTS
No, you pretty much summed it up. New compressor, new clutch or compressor eliminator pulley if they make one and apparently they don't for that one.
SATURNTECH9
  • 30,869 POSTS
I don't see a belt listing for that without ac or a ac bypass pulley.
KJKOBER
can I replace the clutch/bearings even though the compressor won't work? I just need it to spin and get out of the way :)
Thanks!
WRENCHTECH
  • 20,760 POSTS
Yes you can but you're putting money into an already junk compressor.
SATURNTECH9
  • 30,869 POSTS
Sorry wrench tech didn't see you replied to this one when I posted a reply.But auto zone has just the clutch bearing for 15.If the clutch is still good and not locked up you could change the bearing.Auto zone even rents the tools for the clutch I believe.
ANGELA HELTON
I need a diagram it has a serpentine belt.
Jul 29, 2019 at 6:38 AM (Merged)
HMAC300
  • 48,601 POSTS
there are three different engines in this we need to know which one you have there may be a sticker under hood if you do not know. also whether or not it has A/C.
PMF1220
To bypass the ac pulley on my car cuz the ac compressor pulley is messed up pulley is canted the side and the track for the belt is coming off and so is the pulley
Jul 29, 2019 at 6:39 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
Need to know what size engine you have?
PMF1220
i think its a 2.7 liter v6
SATURNTECH9
  • 30,869 POSTS
Here is the belt number i see DAYCO Part # 6PVK1700
PMF1220
Thanks you I really need my car fixed I don't really need my ac this time of year
SATURNTECH9
  • 30,869 POSTS
Your welcome thats what were here for.
OLDSOUL JO
is this the belt size for santa fe 03
SATURNTECH9
  • 30,869 POSTS
Yes if you have a 2.7L engine and your trying to bypass the a.c. compressor.
STACY KNIGHT
What size belt will I need to bypass a ac compressor in a 2005 Chrysler Pacific
Dec 8, 2019 at 12:03 AM
  • 55,746 POSTS
This thread is for a Hyundai Santa Fe.
Please post your new question here, you must be logged in.
Cheers, Ken
Dec 8, 2019 at 4:01 AM
