A/C blows hot
186,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
DAVID07
A/C blows hot at idle.
Changed compressor and condenser.
The mechanic is saying that it’s the fan clutch but I’m not sure.
Aug 28, 2019 at 9:24 AM
BMDOUBLE
  • 1,139 POSTS
This is very likely if your A/C cools off after rolling down the road at speed because you're getting air across the condenser fins which will drop the high side pressure. Here is a guide to help explain the system:
Aug 28, 2019 at 10:26 AM
