When I engage the A/C it blows hot
ANGELO M MARTIN
  • 2007 NISSAN ALTIMA
  • 3.5L
  • V6
  • 142,000 MILES
When I engage the A/C it blows hot. The compressor is not turning. But there is no pressure in the refrigerant lines. My question is, will the absence of refrigerant keep the compressor from working or am I more likely going to have to replace the compressor?
A. Martin
Tuesday, September 10th, 2019 AT 10:53 AM
  • 110,055 POSTS
Welcome to 2CarPros.
The system has pressure sensors. If there is no pressure, it will not allow the compressor to engage. That doesn't mean the compressor needs replaced. What really needs done is to have the system recharged to see two things. First, does the compressor engage and produce what is needed for it to cool the vehicle, and second, does the system maintain the pressure and not have a leak.
Here are a couple links you may find helpful:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
If there is no pressure in the system, what I suggest is to vacuum the system and then recharge it. This is a good idea because while it is under a vacuum, you can determine if it holds vacuum. If it doesn't, then you know there is a leak and further diagnoses needs performed to locate the leak. It will save you money on Freon.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Here is a link that discusses leak detection:
https://www.2carpros.com/articles/air-conditioner-leak-detection
I hope something here helps. Let me know what you find and feel free to ask questions if you have them.
Tuesday, May 25th, 2021 AT 11:27 AM
Related Air Conditioner Not Working Content
