HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Altima
Climate Control
Air Conditioner
Not Working
2000 Nissan Altima A/C not working properly
EDWINBROWN
MEMBER
2000 NISSAN ALTIMA
4 CYL
FWD
AUTOMATIC
150,000 MILES
My ac might work during or on a cool day but during the heat of the day it doesnt work at all
Sunday, June 8th, 2008 AT 3:34 PM
KHLOW2008
MECHANIC
Hi EDWINBROWN,
It doesn't work or is it just not cool?
If not cool during hot weathers, check for operations of condenser fans.
Monday, June 9th, 2008 AT 9:48 AM
EDWINBROWN
MEMBER
Its the compressor thats not kicking on when its on the ac works fine thanks for reponding
Monday, June 9th, 2008 AT 8:02 PM
KHLOW2008
MECHANIC
Hi EDWINBROWN,
If the compressor is not working, then you need to check for gas and power supply.
Tuesday, June 10th, 2008 AT 9:04 AM
EDWINBROWN
MEMBER
Have checked gases and power could it be the pressure switch
Tuesday, June 10th, 2008 AT 11:36 AM
KHLOW2008
MECHANIC
Hi EDWINBROWN,
Loop the pressure switch circuit and see if the AC compressor works.
If it works, then the switch is suspect.
Wednesday, June 11th, 2008 AT 5:58 AM
Please
login
or
register
to post a reply.
Related Air Conditioner Not Working Content
Air Will Not Blow Cold If I Use Heater Then Go Back To...
About A Week Ago I Got In My Car And Switched The Air On And It Was Not Blowing Cold. I Just Had The Compressor Changed In August. After...
Asked by
tiffany3859
2008
NISSAN ALTIMA
VIDEO
Fix an Air Conditioning Not Working Video
Instructional repair video
GUIDE
Like any sub system in today's car a problem and be minor or a little more involved, this guide will help you find the problem and perform repairs. You can be the judge if...
2002 Nissan Altima Heating And Air Problems
Air Conditioning Problem 2002 Nissan Altima 4 Cyl Two Wheel Drive 103, 00 Miles The Heat As Well As The Air Will Work In Spurts, The...
Asked by
lindenberger
2002
NISSAN ALTIMA
My Car Does Not Blow Heat Out From Motor. The Heater...
My Car Does Not Blow Heat Out From Motor. The Heater Door Does Not Open To Let It Out. Why? Please Send A Diagram Also. Thank You!
Asked by
Barnes57
1996
NISSAN ALTIMA
Lowing Hot Air When I Turned On The A/c
My Car Was Blowing Hot Air When I Turned On The A/c So I Put In A Can Of A/c Pro. It Cooled For A Full Day. However, The Next Morning It...
Asked by
Angelianelson73
1 ANSWER
2006
NISSAN ALTIMA
Air Conditioning Leak
I Am So Frustrated With This, My Car Keeps Leaking Inside The Passenger Side When I Use The A/c Or Heater Water Is Ice Cold They Said My...
Asked by
Centralcali209
1 ANSWER
2005
NISSAN ALTIMA
VIEW MORE
Top off Automotive Air Conditioning
Air Conditioner Recharge - Simple
