A/C blows cold air intermittently
120,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
WILDMAN 6D
While driving the air is cold and at times it starts blowing warm air. I play with the thermostat, blend door functions etc. When I slow down to make a turn sometimes it will blow cold and at times it will not. Some days it cold all the time no issues. What's going on so We can fix it.
Aug 5, 2020 at 10:27 PM
Good morning,
Can you give me the high and low pressure readings of the Freon pressures? I need to see them to see if the pressures are correct.
Is the A/C dripping water on the ground? It should drip water.
Aug 5, 2020 at 10:51 PM
