As far as a trouble code, chances are no. What often happens if a sensor malfunctions is it sends the wrong signal. The computer (being a computer) has no idea that it's wrong.
The EVAP discharge temperature sensor can be an issue. And yes, a pain to get to. I have attached a picture of its location. The directions listed below are what is provided. They left the difficult parts out. And yes, half the car has to come apart.
Here is a definition of the component:
EVAPORATOR DISCHARGE AIR TEMPERATURE SENSOR
The evaporator discharge air temperature sensor contains a thermistor which receives a reference voltage from the PCM. The thermistor then varies the resistance to the reference voltage based on the evaporator discharge air temperature. The resulting voltage is returned to the PCM where it is interpreted as an evaporator air discharge temperature reading.
The PCM maintains evaporator core temperature and prevents icing of the evaporator core, by disengaging the A/C compressor clutch when the evaporator discharge air temperature sensor reading falls below acceptable levels, and by engaging the A/C compressor clutch when the discharge air temperature rises above acceptable levels.
The evaporator discharge air temperature sensor is located inside of the heater core and evaporator core housing in the air-stream leaving the evaporator core.
_______________________
Removal and Installation
1. Remove the instrument panel. Please refer to: Body and Frame, Interior Moulding/Trim, Dashboard/Instrument Panel. See: Dashboard / Instrument Panel > Removal and Replacement > Instrument Panel - Exploded View
2. Detach the A/C evaporator discharge air temperature sensor.
3. Disconnect the A/C evaporator discharge air temperature sensor electrical connector.
4. Remove the evaporator discharge air temperature sensor.
5. To install, reverse the removal procedure.
______________________________
The last 6 pictures show how the instrument panel comes apart. I thought I would add them just in case you decide to give it a try.
Let me know if any of this helps. Also, if you could provide the static pressure readings of the system, it may prove beneficial.
Images (Click to enlarge)
Sep 30, 2018 at 12:05 PM
