AC blowing hot air after charging
115,000 MILES • 0.6L • 6 CYL • 2WD • AUTOMATIC
BBMMA
The AC was working fine until we had a heat wave it stopped blowing cold. Recharged the Freon and it worked briefly. Gauge showed it needed more so we added more Freon. Now it blows hot. Please help
Aug 10, 2018 at 3:34 AM
Good afternoon.
What are the high and low pressures for the system while it is running?
How much Creon did you add?
Is the compressor working or is the clutch engaged and the cooling fan running?
Aug 10, 2018 at 7:26 AM
