A/C blowing hot air
200,000 MILES • 4.3L • V8 • 2WD • AUTOMATIC
SCREWHEAD6395
Okay, my A/C just out of no where just started blowing hot air instead of cold. all the vents work it switches to defrost and everything, but when it goes back to A/C it still blows hot air as if the heater is on. Any suggestions?
Apr 29, 2021 at 10:50 AM
  • 110,251 POSTS
This could be a few different things. I need you to check something for me. When you turn the A/C on, do you hear the A/C compressor engage (click under the hood)?
If you do, then chances are it is a blend air door issue. However, this vehicle has one for each side of the vehicle, so I need to know if this happens on both sides.
Also, here is a link that you may find of interest. It discusses the most common causes of the A/C not working. Take a look through it.
Apr 30, 2021 at 2:08 PM
