A/C blowing hot air
56,000 MILES • 4 CYL • TURBO • FWD • MANUAL
PAOLO MIGUEL ROCA METRILLO
This car is the SI model. Now my A/C is blowing hot air i tried recharging it, but still the same. Does the turbo set up has anything to do with it?
Jul 3, 2017 at 8:06 AM
HMAC300
  • 48,601 POSTS
try pulling HVAC fuse inside the car. your manual should tell you where it is for sixty seconds with key on the reinstall. It may be the blend door actuator needs a reset otherwise it could be a bad actuator but should be checked by a mechanic.
Jul 3, 2017 at 8:31 AM
