A/C blending actuator
15,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JOHN KEYES
I had a working both in front not in rear I pulled the fuse under hood 10 amp for a few minutes. Now A/C only works on drivers side five minutes later no ac on either side. any information would be greatly appreciated. thanks
Jun 18, 2017 at 8:05 AM
  • 55,549 POSTS
I would try pulling he fuse again to reset the system. If it still is having problems then it sounds like a blend door actuator is not working. Here is a guide the will show you how to replace and check them out to see if they are working.
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
Jun 21, 2017 at 4:48 AM
JOHN KEYES
Now I have cold air in the front both sides hot in the back I ordered two actuators one for a spare thanks for the information it says 15000 miles it's actually 150000
Jun 21, 2017 at 8:01 AM
  • 55,549 POSTS
Okay, please let me know how it goes,
Cheers, Ken
Jun 21, 2017 at 4:41 PM
