AC and radiator fans
125,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
GIGA_ICE
There are two fans in the front of the engine bay, the radiator and AC fan I assume, when i start the car they spin for about three seconds before shutting off and they wont come on again. The AC is functioning I can feel the heat or the cold but the fans wont blow air out of the vents. I have already checked coolant levels and all the fuses.
Dec 13, 2018 at 10:03 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny,
So, Just a quick question first. Do you mean when you turn the AC/heater on nothing comes out of the dash vents? Hope this helps and thanks for using 2CarPros.
Danny-
Dec 13, 2018 at 10:42 AM
GIGA_ICE
Yes, no air comes out of the air vents in the car. Also, I go under the hood and both the radiator fan and AC fan turn of for a second before shutting off even if the car is up to temperature. The AC clutch is not engaging either and i have already checked all the fuses and relays.
Dec 14, 2018 at 12:47 AM
DANNY L
  • 5,648 POSTS
Hello again,
It's possible the blower motor is not functioning if you're not getting any air at any speed. I have attached a tutorial showing what is involved for its replacement.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 16, 2018 at 5:32 AM
