AC and heat not working
135,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
ZOG1974
  • 47 POSTS
You turn it on in the car hi, low, medium and nothing happens. No AC and no heat. The digital reading comes on in regards to the dashboard, but no air comes out.
May 23, 2017 at 8:25 PM
HMAC300
  • 48,601 POSTS
check fuse in under hood fuse box. check resistor on bottom of heater by blower.
May 24, 2017 at 5:39 AM
ZOG1974
  • 47 POSTS
If I wiggle the wires going into the resister it will turn on but then eventually will shut off on its own and sometimes turn on without doing anything at all
Jul 6, 2017 at 5:42 AM
HMAC300
  • 48,601 POSTS
I tmay be a bad resistor or harness probably resistor is burnt up
Jul 6, 2017 at 8:30 AM
