AC and Fans Not Working - MGCLT Relay Not Receiving Ground - PLEASE HELP!
3.0L • 6 CYL • 2WD • AUTOMATIC
MBORN
1999 Lexus RX300
My compressor cycled on and off a few times. Now, it will not come on automatically and my fans aren't working properly.
Here is some detailed info:
The vehicle was in a minor accident in which it went into a small ditch on the passenger side. The strut and fender were damaged and replaced. This occurred after the accident (to my knowledge...customer states AC worked before and I purchased the vehicle from him).
I can jumper the fan relays individually and they will kick on. I can jumper the MGCLT Relay and the compressor will kick on.
Per the advice of an expert on just answer, I replaced the compressor AND the ECU which did NOT fix the issue.
After further testing, I have realized that I have power going to both sides of the MGCLT Relay. It is not being grounded properly to kick on the compressor. To my understanding, the ECU grounds the Relay?
I'm hoping someone on here has a thorough understanding of how the AC system works and possibly diagrams that my help me figure out why it is not being grounded. Considering I have already changed the compressor and ECU, where could my problem lie?
Thanks in advance
Nov 21, 2015 at 5:13 AM
CAR-MAN145
  • 321 POSTS
I don't know what type of tools you have but I would first hook up a scanner and is if you are getting a/c request to the ecm. It could be the controller but a scanner would tell you that.
Nov 21, 2015 at 5:00 PM
